LoganW 0 Posted November 7, 2022 Hi I had just installed the firmware to my Epson XP 15000 and now when I try to print some digital photos my list of available paper sizes and options are more limited that before. I used to be able to print in 13inch x 19inch glossy sheets but now I only see 5 options and there were probably 15 before this update. Could I get some help with printing a configurable size? Quote Share this post Link to post Share on other sites
LoganW 0 Posted November 7, 2022 When I had completed the firmware upload and activation my printer had restarted and all of the ink levels started to show 100% so I believe the install worked correctly. I also installed new cartridges that are chipless and there are no issue with those. Please let me know any relevant information I can provide to help 🙂 Thank you! Quote Share this post Link to post Share on other sites
Admin 16 Posted November 8, 2022 22 hours ago, LoganW said: When I had completed the firmware upload and activation my printer had restarted and all of the ink levels started to show 100% so I believe the install worked correctly. I also installed new cartridges that are chipless and there are no issue with those. Please let me know any relevant information I can provide to help 🙂 Thank you! Hello! Firmware doesn’t impact this function so unfortunately we cannot help you with that. Quote Share this post Link to post Share on other sites
brus0990@gmail.com 0 Posted June 9 I have successfully updated the software on the HP 15000 printer, which I previously downloaded from your site. But now the problem is that this software - the driver does not support printing in A3 or A3+ format. Are you aware of this problem?.. This question was asked earlier on the forum - but you still did not answer the essence of the problem. Your chipless firmware, posted on the site after installation, does not support printing in A3 and A3+ format... for the HP 15000 printer. Quote Share this post Link to post Share on other sites
