Mely
Activation problem with xp-640 printer
My pc is well connected to the printer, but when I'm going to give it "activate online" It tells me "Read ID code failed" and I have not put the activation code
You should convince that you install the chipless firmware in NORMAL mode instead of UPDATE mode.
If it will be any troubles,write us!
