NishaT
Drop down is blank
When I downloaded the activation to my computer the drop down doesn’t have my Printer to select from. The box is actually blank and not giving an option at all. I am using windows 10. Trying to activate my Epson 2850.
16 hours ago, NishaT said:
I see I needed to keep the USB cord attached.
This might be because there are too many printers on devices and printers. That’s what might help you: close the Activator Software, turn off your printer, go to PC and remove all printers that may be in "Devices and Printers", then turn your printer on and it will install again, then open the launcher software again and it might appear normally.
