EWPCS
WF-7710 ethernet usage
I would like to install the chipless firmware on an Epson WF-7710
I normally use the printer through ethernet connection.
Can I hook up the USB to do the firmware, then return to ethernet connection, or do I need to keep the USB connection in place?
Do I need to disconnect ethernet connection to do the firmware update?
Thank you
Thank you
For  activation process you have to have USB connection-it is obligatory.
Do I need to keep the USB connection in place AFTER activation?
During the activation you need to use a stable internet and USB connection, but afterwards your printer can work as before with any type of connection.
