Novel
I Can't Acctivation online
23 hours ago, Novel said:
My Printer Is Epson WF C 5290
Please try this new file :
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5290_v1.rar
1) Upload firmware which I sent.
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode.
 (No need to press few buttons while turn on the printer)
The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF.
After that try to activate again.
My printer model wf 5290 -
i just bough activation code recently (few hour ago).
and follow your instruction.
in normal mode problem in step 5 . show downgraded it cannot be updated.
in firmware mode - status was finished - but failed reading - 1.
how to solve this problem. .?
On 7/25/2022 at 7:12 PM, hirzie said:
i am from indonesia
my printer current firmware 16.61status.JPG.d200bb204570208b5f9bfe58db289e7d.JPG
- Standard InkChip firmware.
Chipless firmware, which must be loaded into the printer using Firmware Mode.
- 99 InkChip firmware.
Chipless firmware, which must be loaded into Normal Mode.
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed.
4. Start flashing the printer 99 again with InkChip firmware in Firmware Mode. When the firmware status in Firmware Mode reaches 100%, and the printer display finishes counting the percentage of the firmware status, you need to pull out the power cable of the printer. 5. Connect the power cable and turn on the printer. Recovery Mode will appear on the display.
This is just an example of a process, it doesn't matter what model of printer you have. Please watch the video on our official YouTube channel:
https://www.youtube.com/watch?v=h7qWYWjMNFQ
i think your firmware has outdate, becouse no one solve my problem
so i find firmware from another unlock service, and success to downgrade
and then activate use inkchip code.
Edited by hirzie
