Jono 0 Posted July 6, 2022 The firmware never says it’s installed, and just gets to 99% If I try to put the activation code in it just says not recognised XP15000 please help.. Quote Share this post Link to post Share on other sites
Admin 16 Posted July 7, 2022 On 7/6/2022 at 1:41 PM, Jono said: The firmware never says it’s installed, and just gets to 99% If I try to put the activation code in it just says not recognised XP15000 please help.. Please try this new file : https://inkchip.net/download/INKCHIP.net_Firmware_UP_XP15000_v1.rar 1) Upload firmware which I sent. 2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed in your printer! After that try to activate again. Quote Share this post Link to post Share on other sites
