Camila
read failed 01 epson wf 5710
Hola! Necesito ayuda. Instale el firmware que se muestra en la pagina y luego abri el instalador y aparece read failed - 1. Busqué en el foro y encontré otro firmware de mi impresora epson 5710 y decia que se debía instalar con la impresora prendida en modo normal, lo cual no resultó, ya que desde que instale el firmware anterior, mi pc solo reconoce la impresora cuando esta en modo instalación de archivos (power+job status+4+7). Asi que ya no se que mas hacer. Tengo la key comprada. No se si el error se debe a que no me queda tinta en los cartuchos antiguos o por que. Quedo atenta a su respuesta.
On Epson wf5710 when flashing into chipless version, when activated there is an error "Wrong ID printer from the printer" or "Reading failed 1". Also, the problem described here can manifest itself in the form that after successful flashing and activation of the printer still requires the installation of ink cartridges.
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain key combination is pressed.
This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles.
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5710_v1.rar
My printer XP-434 failed when activate. " Reading Failed -1 "
Edited by Kim
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar
Your all firmware version 99 you sent are not work with my Epson XP-434.
My solution is I manage to download firmware from another seller reset chip : That is MO23HA version. This work for me now.
On 3/10/2021 at 7:55 PM, Hesham said:
Make sure that you are using a functioning USB cable and that the slot works.
Also, see if the computer itself sees your printer in the "Devices and Printers" menu.
Vamos lá pessoal. Demorei mas consegui resolver essa situação executando os seguintes passos:
Primeiramente eu atualizei a impressora ligada normalmente com esse executável de outra empresa que faz o desbloqueio (creio que ele faz o downgrade da versão original mais antiga).
https://drive.google.com/file/d/1jNI81_avc1uG9VSgw00VtVX9iGL5Zl4o/view?usp=sharing
Ele aparece no visor da máquina que está atualizando o firmware.
Ele não vai até 100%. Mais ou menos em 87% pode remover ele da execução. Ao reiniciar o equipamento está tudo certo.
Logo em seguida eu fiz a atualização normal em modo de atualização de firmware com o link abaixo
Entrando no modo 4+7+Status+Power
https://inkchip.net/download/INKCHIP.net_Firmware_WFC5710_v3.rar
Com esse ativador
https://inkchip.net/download/INKCHIP.net_Activation.exe
Aqui deu tudo certo...espero que dê aí também.
