Colorado English
EPSON Workforce Pro WF-C5710 Activation Reading Failed -1
Activation: Reading Failed -1
I have successfully installed the firmware using the download and instructions. But when it comes to Activation, I continually get the following error message. How can I remedy the situation?
Order #: 7760
i have a problem  epson wf C5710
i try to use the firmware 99
the new firmware can't find my printer in the 5th step,
Error: "the printer is disconnected or the printer is different with the model"
[Order #21963] (February 19, 2021)image.png.0517b485c99e158dfbf376199e1cc6b2.png
- Firmware Mode - special mode for updating printer firmware, which is activated when a certain key combination is pressed.
This is just an example of a process. It doesn't matter what model of printer you have. This video is in Russian, but you can turn on English subtitles : https://www.youtube.com/watch?v=Duyj-UHbzxE
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF5710_v1.rar
i cant flash the printer with firmware 99 in the firmware mode (pressing  few buttons while turn on)
error message in screen of printer: "NO DATA"
No, your model is not supported by WIC.
Which archiver are you using to open the firmware?
Also, make sure the printer is connected to your PC with a USB cable.
Vamos lá pessoal. Demorei mas consegui resolver essa situação executando os seguintes passos:
Primeiramente eu atualizei a impressora ligada normalmente com esse executável de outra empresa que faz o desbloqueio (creio que ele faz o downgrade da versão original mais antiga).
https://drive.google.com/file/d/1jNI81_avc1uG9VSgw00VtVX9iGL5Zl4o/view?usp=sharing
Ele aparece no visor da máquina que está atualizando o firmware.
Ele não vai até 100%. Mais ou menos em 87% pode remover ele da execução. Ao reiniciar o equipamento está tudo certo.
Logo em seguida eu fiz a atualização normal em modo de atualização de firmware com o link abaixo
Entrando no modo 4+7+Status+Power
https://inkchip.net/download/INKCHIP.net_Firmware_WFC5710_v3.rar
Com esse ativador
https://inkchip.net/download/INKCHIP.net_Activation.exe
Aqui deu tudo certo...espero que dê aí também.
