15 hours ago, Dve said:
I have the same problem, help!
Please specify your printer model and which mode did you install the firmware in.
On 4/1/2023 at 11:29 AM, PeterPeter said:
I have the same problem too.
XP-15000 printer. normal model.  Order502681  USB connect and Windows 10 /11
You should install the Chipless Firmware in NORMAL mode instead of UPDATE mode.
