Slty 0 Posted March 23, 2023 what button should I push Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed Quote Share this post Link to post Share on other sites
Admin 16 Posted March 23, 2023 19 hours ago, Slty said: what button should I push Firmware Mode - special mode for updating printer firmware, which is activated when a certain buttons combination is pressed Hello! The original firmware of your printer cannot be downgraded to earlier version. Please, follow the instructions below. The firmware, which you need to use: https://inkchip.net/download/INKCHIP.net_Firmware_2022June_WF5790_v1.rar Algorithm for solving the problem: 1) Check and memorize current firmware version of your printer. 2) Start installing the firmware in the Firmware Mode (by pressing a certain button combinations) 3) When the firmware installation reaches 100% you need to disconnect the power cable from your printer. Wait for about 10 seconds and then plug the cable in. A message will appear on your printer screen, saying that the printer is in Recovery Mode. 4) Start installing the Inkchip firmware again, wait for the firmware to load, your printer will shut down. Turn your printer on. 5) Check your printer's firmware version. It must be different. This means that the process was successful. 6) Now you need to use the Activation Program from our website and activate it with the key. After the activation you have to reboot your printer. The chipless firmware is installed on your printer! Please watch the instruction video from our YouTube channel for a clear explanation: https://www.youtube.com/watch?v=h7qWYWjMNFQ This is just an example of the process, it does not matter which model of printer you have. Quote Share this post Link to post Share on other sites
UTAMA 0 Posted April 14, 2023 Same problem here. I tried the instruction above to downgraded the firmware version between 2019-2020 but always failed when downloading the firmware. Stuck at 21% and back to 1% again . My printer is Epson - WFC5790, order number 505885. How to resolve this? Quote Share this post Link to post Share on other sites
Admin 16 Posted April 14, 2023 8 hours ago, UTAMA said: Same problem here. I tried the instruction above to downgraded the firmware version between 2019-2020 but always failed when downloading the firmware. Stuck at 21% and back to 1% again . My printer is Epson - WFC5790, order number 505885. How to resolve this? Hello! You should install the Chipless Firmware in NORMAL mode instead of UPDATE mode. Please read the instruction from our website carefully: https://inkchip.net/download/INKCHIP Instruction Method 14 (for 99 firmware).pdf Also, please watch the video guide from our official YouTube channel: https://youtu.be/oF0DsDVPT7k Quote Share this post Link to post Share on other sites
