Rafael Alvarado
Epson WF-C5790 read failed - 1​ 👉 ​ I have problems with the activation
12 hours ago, Rafael Alvarado said:
The online activation does not work! Can you help me solve this problem?
I use this Firmware
https://inkchip.net/download/INKCHIP.net_Firmware_2022June_WF5790_v1.rar
Also use this activation
https://inkchip.net/download/INKCHIP.net_Activation.exe
and i use windows 10
You should install the Chipless Firmware in NORMAL mode instead of UPDATE mode.
Please read the instruction from our website carefully:
Also, please watch the video guide from our official YouTube channel:
When I did the installation and the firmware in normal mode, it also happened that the printer was not detected when installing the firmware. That's why I had to install it in update mode
What I can do?
TENGO EL MISMO PROBLEMA CADA VEZ QUE QUIERO ACTIVARLO ME APARCE ESE ERROR Read Failed -1 que debo hacer?
Debería instalar el Firmware Chipless en modo NORMAL en lugar de en modo ACTUALIZAR.
Por favor, lea atentamente las instrucciones de nuestro sitio web:
También puedes ver la guía en vídeo de nuestro canal oficial de YouTube:
¡Háganme saber el resultado!
Gracias.
