EWPCS 0 Posted August 15, 2022 I would like to install the chipless firmware on an Epson WF-7710 I normally use the printer through ethernet connection. Can I hook up the USB to do the firmware, then return to ethernet connection, or do I need to keep the USB connection in place? Do I need to disconnect ethernet connection to do the firmware update? Thank you Quote Share this post Link to post Share on other sites
Admin 16 Posted August 16, 2022 On 8/15/2022 at 7:05 AM, EWPCS said: I would like to install the chipless firmware on an Epson WF-7710 I normally use the printer through ethernet connection. Can I hook up the USB to do the firmware, then return to ethernet connection, or do I need to keep the USB connection in place? Do I need to disconnect ethernet connection to do the firmware update? Thank you Hello! For activation process you have to have USB connection-it is obligatory. Quote Share this post Link to post Share on other sites
EWPCS 0 Posted August 16, 2022 Hello, Do I need to disconnect ethernet connection to do the firmware update? Do I need to keep the USB connection in place AFTER activation? Quote Share this post Link to post Share on other sites
Admin 16 Posted August 16, 2022 During the activation you need to use a stable internet and USB connection, but afterwards your printer can work as before with any type of connection. Quote Share this post Link to post Share on other sites
