On 12/16/2021 at 2:19 PM, dimon26072001 said:
Please help me on my XP-434, we have the same problem
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP430_v1.rar
Please help me on my XP-340, we have the same problem. I get the Read Failed -1 when I try to use the activation program.
Epson WF 2830
Updated the firmware last night and bam. Not allowing my aftermarket print cartridges to be recognized anymore. Found Ink-chip.net,, Downloaded the Chip-less firmware and activation software.  When I go to install the firmware software it comes back with error "( Could not find files to start)".  Whats up with this?  Id like to fix my printer but it seems like this is a 1/2 written program and not working well for anyone.  Current firmware version on Epson WF2830 is AL2213.  Any help would be appreciated.
22 hours ago, JIMEA said:
Epson WF 2830
To extract a file you need to use any archiver. For example, WinRAR or other unzipping program.
On 6/4/2022 at 8:40 PM, helen said:
hi i am having the read-1 error when pressing activate online with my wf-2850
please help
Please try this new file:
https://inkchip.net/download/INKCHIP.net_Firmware_99_WF2850_v1.rar
1) Upload firmware which I sent.
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode.
 (No need to press few buttons while turn on the printer)
The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF.
After that try to activate again.
Hello! Please try this new file for you:
https://inkchip.net/download/INKCHIP.net_Firmware_XP4100_v1.rar
2) Switch on in normal mode(!!!) just turn on button . - dont put printer in Program Update mode. (No need to press few buttons while turn on the printer) The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF.
Im sorry this does not make sense.
It will not update the firmware when it is in Normal mode.
Please advise
My printer is the XP-2150. The firmware program always gets stuck at 99% even if I unplug the printer then turn it back on. I always run it on regular mode and the program on administrator mode with antivirus turned off. This makes no sense..
Please try this new file :
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP2100_v1.rar
19 hours ago, Moacir said:
Estou com problema na Epson xp-231, gostaria de uma solução. Não está dando certo.
da erro de leitura.
Describe your problem in details please. Send the screenshot, if possible.
23 hours ago, andrewj320 said:
I also have the same problem on epson xp 15000
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP15000_v1.rar
I have the same problem to my XP-235 series. I tried the firmware and thru the program update mode. Then in activation, it says read failed -1.
I tried then with your process doing it normally not on program update mode, but the firmware can't install be installed.
https://www.dropbox.com/s/qrbj69mpxsnzmhy/Screenshot%202022-11-23%20140635.png?dl=0
https://www.dropbox.com/s/qexei5wa6b4964r/Screenshot%202022-11-23%20140743.png?dl=0
https://www.dropbox.com/s/qrbj69mpxsnzmhy/Screenshot 2022-11-23 140635.png?dl=0
https://www.dropbox.com/s/qexei5wa6b4964r/Screenshot 2022-11-23 140743.png?dl=0
Please try this updated file with the Chipless Firmware:
https://inkchip.net/download/INKCHIP.net_Firmware_99_XP235_v1.rar
1) Upload the Chipless Firmware which is attached above.
2) Turn on the printer in the NORMAL MODE (using only the power button). Do not put the printer in the UPDATE MODE.
The loading process will get stuck at 75-85% - that is OK.
3) With the use of the task manager stop the loading process.
Printer will blink for about 5-15 minutes . It should then turn off automatically.
4) Now turn on the printer - Chipless Firmware should be installed!
5) Run the Activation Software to insert your Activation Key.
Thanks!"
Thanks!"
Hello. I have tried the above method, but still,  it says reading failed. The moment I use the activation software. Also, the normal mode does not work. It gets stuck as early as 14% and says that it does not detect the printer (unless in UPDATE MODE). Is there any workaround regarding this problem?
